Hi I love the look of decking instead of paving. However I am concerned with the spider and other insects that might build nest under the decking. My second choice is polished porcelain. Can anyone advise the advantages and disadvantages of decking ?
Thank you
Decking
Thank you
Disadvantages, as others have already pointed out, is that they need to be treated with either an oil based or acrylic formulation. And decks that are not under cover require much more frequent maintenance. If your deck is under a pergola and you use one of the better water based acrylic treatments, you could go up to 2 years without having to redo it. Without cover it's a different story however.
I've had both pavers and decking and I'd go with a deck if under cover, and pavers/tiling if not under cover.
If you want tiles, and there is a distance from the ground, try steel framing then Hebel; we had to do that as we are in a fire zone, and it's fast to put up.
Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks
19/08/2023
1
Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for…
5/02/2024
Hi, Really struggling to find some consistency amongst Span Tables, can anyone help…
