Paving or Decking
decking or polished concrete is my vote
Depending on the area you have to work with it may be possible to use a little of both.
paving's lots cheaper but then ants can bring up the soil between the cracks and weeds love to invade and grow in the tiny gaps. yes we have paving. 250m2 of it. On the plus if soak wells below pavers need repair/replacing or piping gets blocked its a simple matter to lift the paving to fix it. Much simpler than jack hammering concrete and having to replace it later and get the same colour/look etc especially if it's not plain grey.
Is it legal in Australia (NSW and Vic in particular) to use one of those gas weed burners to singe the weed? Obviously, i mean when there isn't a total ban of open flames. I have used one for years, and it really works well. You don't actually burn the weed, you just singe the surface of it and it then dies. I'm asking because I'm also contemplating whether paving or croncrete - or cobbled stone would be the best choice.
Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks
29/08/2023
3
I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.…
26/12/2023
10
As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide…
