Alfresco enclose
I'm recently started to build a house and left alfresco around 25 square meters. Post build I found the actual living areas looks smaller. The current alfresco is under main roof as well as the flooring is under the main slab with tiles layedout.
Is it possible to add mirror doors on both sides to have a beautiful living room ? That will fulfil our requirement. I have good and enough space on the backyard.
Please advise/ suggest your opinion.
vivhome welcome to the forum
Did you search the forum, as it's a popular request?
Here this might help
Need ideas to converts alfresco into bedroom
Cheers
Chris
Hey Did you search the forum, as it's a popular request?
Cheers
Chris
Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof…
2/02/2024
Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill…
14/04/2024
2
thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and…
