Laminex bench top
Ask for the benchtop to be made on aquaban blanks. The underside of those boards are coated in melamine so it helps protect both sides of the board from high humidity.
Personally I always build with waterproof materials in alfresco settings just because I feel it's best practice, but I've seen plenty of standard internal style kitchens installed in alfresco areas that have lasted well.
If it's never going to get direct rain you should be fine.
What do you mean by aquaban blanks? I looked up the meaning and nothing came up.
It just means the whole board has a coating and will help with humidity.
Some postformers use them all the time some just use raw blanks. I'd just specify it to make sure.
Here is the link.
https://www.laminex.com.au/products/aqu ... /AU1000055
Post formed laminate benchtops are often pressed onto raw MR particle board blanks which means the underside is just a raw particle board finish. That's fine for a kitchen but aquaban blanks have one side with a melamine finish. This goes on the underside so you have laminate on the top and melamine on the underside.
Here is the link.
Here is the link.
Great advice. Thanks mate.
12
These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is…
14/09/2023
4
Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges.
27/04/2024
1
Caesarstone, quantum zero, Q Stone zero, porcelain. All the manufacturers are pivoting into zero silica materials. Google any of those and have a look. Some are still…
