How to know if the air vent pipe is blocked ?
Seal each pipe in turn, and then both, and test to see if that causes any change. If it does, that could narrow down your culprit.
I doubt it's the vent pipes.
The blockage will be in the drains.
7 metres isn't really long enough to try and clear blockages. Get a drain cleaning specialist out. They use high pressure drain cleaners and cameras to inspect all the drains.
We had a similar issue at our rental. I watched him work and saw the before and after pictures. It only took 30min and at least the camera verifies what the actual issue is
Thank you for your advice.
Thank you very much..
Appreciate all your advice
