Cost of custom timber joinery
Looking at solid timber. Build and install.
Cladding for back and side of kitchen return:
Back: 1 piece 800mm high x 1400mm wide
Side: 1 piece 800mm high x 600mm wide
Frame for fridge: 2480mm high x 800mm wide with three horizontal shelves built into the top (no back)
Shelving to sit between upper kitchen cabinets: 1000mm high x 800mm wide (a box design with three shelves built in - no back)
I will be looking to get quotes from cabinet makers soon but just want to get an idea of whether the cost will be somewhere in the range of my budget - otherwise the whole kitchen design will need to change!
5
Pulse is correct. It's the trap that takes up space. The plan shows a vessel style basin so you don't have to worry about a basin inset, it's just the trap that the…
30/05/2024
15
Thanks Chippy, that makes me feel relieved with our Poly cabinets. All the best with the build Sara.
6/07/2023
1
Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity.
