Waterfall edges after handover?
We are building with Eden Brae and thinking of not doing waterfall edges for kitchen. EBH gave a estimate, for 2K for 2 edges. We thought using that money for something else for now and do the waterfall edges later. Is it possible? Will it be cheaper? Do we have to take some action to now to allow the waterfall edges later?
Thanks
Don't waterfall edges have a mitre join? If so, you would need to have the benchtop ends cut to suit.
Thanks
I just had temporary bench tops with my build and am getting natural granite and marble for less than the builders price for manufactured stone after handover
You can do them with a shadow-line joint instead. You’d need the ends to have a 20mm overhang
I like the idea of having a temporary bench top and replace with the one we wanted. Do they installed the waterfall over the tiles?
We are doing our own vinyl planks after handover. We’ll have the stone done first so it can be laid on the hard surface.
You can sit them on tile not a problem
4
yes it does, you've just not understood it. theres a difference.
13/11/2023
1
Your house should come in "as new" condition. It should be clean, and without stains
10/05/2024
3
Hi Need to read your contract about when final payment is received. Clearly outlines what happens. In vic, known defects or incomplete work must be completed before…
