Any information would be fantastic, and also I welcome any photos!
Who has used marble/stone for their splashbacks?
You need to tell the cabinetmaker in advance that you are having stone splashbacks as the bench top needs to be slightly deeper to allow for it.
Having a glass stove will we need a wider top anyway?
It doesn't have anything to do with it being glass. Its all about where the elements are. Some are very close to the back edge and you would need extra bench top depth to allow for it especially with a stone splashback.
All cooktops are different and you really need to pay attention to the dimensions and layout.
Sorry for the mix up.
Gas stovetop**
Exactly the same answer
Im having Ceaserstone Ocean Foam benchtops and decided to continue it for the splashback.
Reason is, I'm a bit over the glass, and have never loved it.
Had the tiled splashback in the last house, so looking for a change.
Hopefully it will look great.
It looked very smart and was a change from the normal glass splashback. The continuity between the bench and splashback was nice.
I had to make extra allowance for depth around the stove top so as CEK mentioned make sure you tell your cabinet maker you are having stone.
Hi All, This is my first bathroom Reno and tiler has just finished installing marble tiles…only problem is they don’t look right? There are holes in the grout, really…
3/09/2023
Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best…
4/10/2023
3
Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters…
