Laminate panels for island ends
If so I would strongly recommend against it. Laminate edges chip very easily if no post formed(rolled like a pencil round)
I have seen it done before and around foot height it tends to chip badly.
Are you talking square laminated??
Afraid, we've got polytec to our island drawers. Maybe they've rolled it though? They're doing handless drawers so they'd have to form it up somehow..
Custom knockdown rebuild Newcastle NSW
viewtopic.php?t=78271
[Afraid, we've got polytec to our island drawers. Maybe they've rolled it though? They're doing handless drawers so they'd have to form it up somehow..
Polytec what though??
It may be a prefinished melamine with a PVC edge.
The OP mentioned laminated panels which chip badly.
Ursula123 are you able to clarify exactly what product you are talking about when you say laminate?? A lot of people use the work laminate for prefinished melamine, the two are totally different!
Ah I see.. Well ours is the polytec ravine colours?
[Ah I see.. Well ours is the polytec ravine colours?
So polytec ravine comes as a laminate and also 18mm prefinished board. Two completely different products! Again more info needed.
The laminate is only 1mm thick and glue to a substrate on all faces and edges, the corners unless post formed chip quite easily.
The pre finished board comes either 16 or 18mm thick finish in ravine on both sides. Once cut to size the edges are normally finished with 1-2mm pvc edging which is a lot stronger than laminate.
Ah cool. Just checked our detail it's "polytec melamine board with PVC dura edge" on the island bar and and drawer fronts. Rest of the kitchen is 2PAC satin finish.
[Ah cool. Just checked our detail it's "polytec melamine board with PVC dura edge" on the island bar and and drawer fronts. Rest of the kitchen is 2PAC satin finish.
Perfect, that wont chip and is much better than laminate for those areas!
Learn something new every day.. It's a pretty decent outfit I think whose doing our cabinets so I wasn't too worried
Thanks CuttingEdge. Our plans say standard melamine with 1mm PVC edge. The specs for end panels just say80mm mitered polytec melamine, and the doors for the island say polytec melamine with 1mm PVC edge. Reckon that's alright?
If the 80mm end panels go to the floor and are mitred then the corners will be very week. A knock with anything hard will dent/chip the corners easily. Just try and be very careful.
Hmmm it's not too late to change! I was thinking of doing something different (and cheaper) than the stone waterfall ends. I've seen thick end panels with a profile, would that be vinyl wrap do you think? Thank you for your advice, I really appreciate it.
Hi Ursula
I'm looking into something similar to what you were asking. Would be great if you went ahead with it.
I have a 40mm overlap on each side of my bench top, looking at options of either timber or if it can be done laminate good, even vinyl wrap sounds good as long as it matches cabinetry.
Here's a pic of what I want to achieve
I have same colour cabinetry. Look forward to hearing your progress
viewtopic.php?t=79203
Hello - we were hoping to apply laminate click lock panels to our concrete ceiling, but not too sure how to go about attaching the panels to the concrete. Any idea what…
