Stone Benchtops - Possible for supply only?
Apologies if this is in the wrong section, but I guess it's Kitchen related...
I've got a few small outdoor benchtops that I'm looking to do in engineered stone. I realised it's not "supported" outdoors, but I've personally seen heaps done this way and they look fine so long as it's not fully out in the elements.
Does anyone know of any online place which will ship small slaps of Caesar? The biggest section is only 800*600mm which is going to be less than 50kg, so it's easily handled and installed.
The reason I'm looking to do it this way is because no one is interested in coming out just to do small slabs like this, and even less interested when they realise it's an outdoor installation.
Give him the sizes you require and you pick it up. Most would be happy to do that.
You should ask stone mason if he has any offcuts available to suit your measurements. Good luck
http://www.konnectkitchenstore.com.au
We bought our stone benchtop from that store for our extra kitchen. You could get a full sized 3M stone between $400-800 plus $250 for the masonry to cut and polish if you want a smaller slab. A lot cheaper compared to other stores.
Try this We bought our stone benchtop from that store for our extra kitchen. You could get a full sized 3M stone between $400-800 plus $250 for the masonry to cut and polish if you want a smaller slab. A lot cheaper compared to other stores.
6
That's a fantastic result! Happy you got it sorted out. cheers Simeon
16/11/2023
1
You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete.
