Kickers advantages and disadvantages of different materials
eg laminate, brushed aluminium (?) etc, stainless. Sorry if this has been posted before.
What do you consider a better quality product, outside of the aesthetics which are a personal preference.
The material listed would be just a personal choice of the look your after, the question is what material are they laminating these onto ? Most seem to just use pineboard laminated or even worst MDF with the finish of choice but the edges are unsealed and will draw up moisture easy. Get an off cut of pineboard and stand it on its edge in a small tray of only a few mm's of water and watch it drink and swell. A decent cabinet maker uses Plywood for their substrates and kickboards.
Totally agree with above, here is a photo of the plywood kickboard we make.
Thanks for your replies.
So if the kicker is say brushed aluminium it will be affixed onto a different material eg MDF, pineboard, plywood?
I just rang the first place we are quoting with, they use plywood so that is good. I think they are pretty decent.
Yes, brushed aluminium is only a laminate that is 1mm thick and needs to be bonded to a substrate.
Stainless steel kickers are expensive. Brushed aluminium laminate looks good and is much cheaper and looks good, this is our kitchen...
Hi charlsto, just wondering what colour your cabinets are? And the finish?
Using a phone. Please excuse typos and autocorrect issues. And brevity.
6
That's a fantastic result! Happy you got it sorted out. cheers Simeon
15/01/2024
1
in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most…
11/11/2023
2
yep you need a joint, foam is easiest, will look fine once rendered with a joint.
