Undermount front loader in kitchen?
I'm thinking about getting the front loader undermounted next to the dishwasher in the kitchen. Any thoughts? The same issue applies, size. I'm not sure I want to get the cupboards built to spec to fit a particular machine.
EDIT: Keeping with the theme of washer in the kitchen, the mixers with hoses: will one of those generally reach to fill a bucket either on the drainer or the floor? Seeing the washer will be in the kitchen I'll have no laundry tub.
I've got no issue with the washer in the kitchen, it's very english though. I would consider what your plans are for the property, sell it soon? Stay forever?
People buying a house will notice the washer in the kitchen and may not like it, people wont notice the issue with the door until they've bought it and moved in.
Here is a rough plan. It's not to scale with correct measurements because a)I'm on holiday and b) I'm a donkey when it comes to measurements and scale
Currently I have one bench and if I want to put four dinner plates on the bench to serve dinner I have to move the coffee and sugar canister to the top of the fridge. I'm working with a very small space and extending is cost prohibitive, it won't make the room longer just deeper and I'd not add much value to the house. I'd rather work with the space I've got and maximise the use of it.
You could swap the hinges on the fridge door to better accomodate the opening door.
You'll also be less likely to accidently open the door when the fridge is open (assuming there's some kind of window in the door)
Tough space, ill think some more
The pantry can be custom width and depth.
ta.
if you are going to have the washer in the kitchen, make sure it is concealed behind cabinetry so you cant tell.
can you change the back door so it opens the other way in, and wont hit the open front loader door?
Sounds like a good idea!
You can get the Asko integrated washing machine, it's designed to be integrated behind a cupboard door without increasing the depth.
1
that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink
18/12/2023
1
Old Home Restoration / Renovation
Try your local council. They should be able to advise in regards ownership of next door dwellling and give advice as to what steps you have to take before doing any work
