Can you change the laminex covering for cupboards?
What options are there to change it once it's installed?
For example, can you simply cover it with another laminex coating? What about removing the previous one? Would it be a major endeavour? Would we need to remove the base carcasses / frames to change the laminex?
Here are a few links I found:
http://livingwithlindsay.com/2009/05/ho ... iture.html
http://www.ehow.com/how_2325302_paint-l ... inets.html
There's also one on youtube. I do believe there are tradies out there who also do this if you don't want to do it yourself.
More than likely it is lamiwood a prefinished laminex board with PVC edges???
You could laminate over it but I would recomend against it. You can also paint over it either by hand or with polyurethane but you can end up with small cracks where the edges are.
If you do end up painting dont be talked in the expensive Bunnings laminate primers. They are a waste of money!!! All you need to do is give the face of the door a good sand and then use a standard undercoat.
12
got it. thanks. I was looking for word ' Adobe' and added filter. all good.
27/04/2024
1
Caesarstone, quantum zero, Q Stone zero, porcelain. All the manufacturers are pivoting into zero silica materials. Google any of those and have a look. Some are still…
