Island Bench - having to use two pieces of stone
Wanted advice please. We have an island bench that someone has suggested widening. We agree this would look great. Problem is in the island bench there are two supporting beams going to the cathedral style ceiling. If we widen the bench the guy giving the quote said we would have to use two pieces of stone and that we would see the join as it would have to accomodate the beams. Not too keen on this - anyone had the same issue?
You can barely see the join unless you stand right over it.
Perhaps if you get some pictures others could offer advice.
I will be having a similar problem when we upgrade our kitchen bench as it 4.75mt long and longest stone slab we could find was 3.15mt
We also considered StaronĀ® Solid Surfaces which could possibly be installed in your situation without any visible seams.
3
Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or…
29/05/2024
3
Well, it was the default we got with our deign, walking through the build last week felt ok, based on drawings on the floor, it is basically a metre, which is quite a big…
