Diamond Gloss cupboards?
However my builder just informed me that we can't use DG, and I haven't been told why.
Is there a technical limitation I don't about?
We can use it on our benchtop however.
Any ideas?
This may help you a little in your search for a reason. We wanted to use particular laminates gloss and
also Diamond Gloss's on cabinet doors and this was the answer. They didnt say it could not be done in the
gloss instance, but mentioned it would cost quite a bit more.
"They use a 16mm prefinished board to make the doors out of, where they cut and edge the product. The cabinetmaker would be hand laminating every door and drawer front. Unfortunately there is not an option of finish with the 16mm board."
So they main answer was many of your default laminates come in this prefinished board they use for doors and cupboard faces. Not all of these new gloss laminates are available in the prefinished boards. Other option many go for in that case is 2pak painted finish.
Ozz
There are a couple of manufacturers providing a semi gloss finish in melamine now, most notably the "Sheen" range from Polytec - this finish is a very good alternative to high gloss two pack or gloss laminated boards.
Polytec have also recently released their new range of Createc boards which are finished with a high gloss.
From what I understand (but don't quote me on this) the Createc uses 18mm coloured melamine which is then coated in a high gloss resin, giving it a very strong lustre.
Both of these options provide durable and good looking boards that can be considered as viable options to other more traditional gloss finishes.
Cheers,
Earl
as they have this in the prefinished 16mm board. Warm White gloss (formica) i think was one.
Ended up going Snowdrift Pearl finish instead. I think in one thought with a super gloss door you
would be forever wiping smear marks off them.
It is possible.
I have been told an alternative is a 'gloss vinyl wrap door' that is $120 a door
Thanks for the info guys
Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best…
15/01/2024
4
This link might answer your question. I had the same issue and it turned out to be the roller. https://www.sherwin-williams.com/painti ... %20coating.
