Stone Waterfall "After" Flooring Install
The kitchen installers say that they can draw a line to indicate where the stone waterfall will go and the floorers can then install up to that point, then the stone can go in, still with a good finish between the stone and the floor. Is that right? I'm worried about a gap between the two. To add to it, the flooring guys are adamant that the stone cannot go on top of the hybrid flooring as it may buckle under the weight. Any advice?
6
That's a fantastic result! Happy you got it sorted out. cheers Simeon
3/09/2023
Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best…
4/10/2023
3
Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters…
