We have just recently replaced a double oven with a single oven, but the new oven is not as wide as the old and couldn't be mounted to the cupboard. I'm thinking of building a frame for it and having a shelf above it. The gap on each side of the oven is around 60mm. Could something like this do?
Here, I'm using 70x35 (x6) for the frame and a piece of 18mm plywood across the top as a shelf. Because the sides are only 60mm wide, the bottom supports would be 70mm high. Is there a good way to screw them down? Or will it be a better idea to ask Bunnings to split 70x35 into 35x35s?
Any advice appreciated. Thanks.
