Plumbing behind fridge - affect the depth?
Page 2 of 3
Btw, I don't see why one wouldn't have the recess-box, but in the cupboard next to it. The best of both worlds. And if you could have a small stop thingy (I have no idea what they're called in English) at the outlet from the wall, so much the better, instead of having to turn it off at it the mains at the slightest problem.
Here in Australia there are no shut offs for many kitchen sinks, or bathroom vanity's. So how would you shut the water off there in a hurry? The same way you would if you had a leak in the fridge water line, and wanted to turn it off in a hurry. TURN IT OFF AT THE MAINS! that simple.
Actually all our taps have separate shut offs, be it in the kitchen, laundry or bathrooms, but this is a newer renovation. And the taps for the dishwasher and washing machines were all plumbed into the cabinet adjoining the appliance; I had wondered why, but as CEK mentioned, was told it was for quick access in case of failure. They obviously didn't trust the automatic shut-off on both the dishwasher and washing machine...
As for the mains, it's fine if your main is close at hand, but ours is over 30m up the hill from the front door, which isn't close to the kitchen.
If you have fridge recess 800mm or deeper then sure you can put it there without it impacting the space in front of the fridge but I just think it is bad building practice for the reasons I and others have mentioned in other posts above.
Stewie
Please be reminded of the following.
I would like to point out to you the HomeOne Forum Terms of Use viewtopic.php?f=1&t=19734 regarding posting, and in particular this paragraph: <edit html to create hyperlinks>
<Quote>2. Be respectful of other members at all times. Flaming or abusing (incl. bullying, belittling or humiliating) other members in any way is not acceptable. Any post deemed disrespectful or defamatory of another member or party will be removed, and the poster will be at risk of being banned. <end quote>
<We appreciate the value of members such as yourself, with experience in the building and related industries> <We appreciate the valuable contributions you have made to the forum to date> <We welcome lively debate between members> and would like to see you continue to provide helpful input. But please keep in mind that it is possible to disagree with another member without resorting to abuse or ridicule.
Please consider this a formal warning. Any future breaches of this nature will result in a permanent ban.
kexkez
Support Team
SHOULD YOU REQUIRE ADDITIONAL SUPPORT PLEASE REPLY TO THIS SUPPORT MEMBER ONLY OR ALTERNATIVELY CONTACT FORUM ADMIN HERE: http://www.homeone.com.au/contact
Apologizes to First_Timer_Ray for letting this continue for so long.
Just to give you something else to mull over. If putting the shut off behind the fridge should never be done, and only put in a cabinet. Can you tell me where the shut off went in YoullNeverWalkAlone's kitchen? I'm guessing you would have put it in the open space behind the books.
************************************************ edited by kexkez Homeone Support Member.
There are always exceptions and you don't have much option in this case.
BUT if you have an option it should have a shut off tap that is easily accessible without the need to remove the fridge!
Thanks Roger, this is pretty much the same layout to our kitchen except the island runs the other way, with the fridge facing the end panel. We have no surrounding cupboards, and like this photo, we have a walk in pantry to one side (with only one door).
At the end of the day, it is how it is, I'm not about to rip our kitchen apart for the sake of a tap which is already there. I was merely trying to find out how much others' fridges protrude that have plumbed ice/water.
I would be interested to know how much the above fridge is sticking out because it looks fine to me. If it's in the same vicinity as the one we are looking at I would happily buy it.
Thanks Kexkez for keeping the thread on topic.
If your current depth of cupboards are 705mm with a tap behind that sticks out 55mm that leaves you 650mm then just suss out the fridge you want to buy. Look at the specs and compare.
Whatever the difference will be how much your fridge sticks out.
Look at how the doors pivot too. Most open out past the side of the fridges about 20-30mm.
For this reason the back of the fridge doors should be parallel or slightly in front of the adjoining cupboard doors depending on how much space you have left either side for the appliance ventilation.
As you say, it is how it is and unless you decide to spend a fair few dollars to re-position the tap you may well end up with your fridge doors sticking out 150mm but that depends a lot on whichever fridge you choose.
Stewie
From the fridge handles to the bench is 980mm but it’s a huge gap and you could cope with less space. This is also our entry to the kitchen and we have never had any issues.
Ray, your kitchen / pantry / dining area sounds the same as ours, this shot shows how it looks.
http://i1055.photobucket.com/albums/s507/grumblebum54/fridge1_zpsa56c0de6.jpg
Judging by what another member PMd me and your responses here I think 10-15cm outside of the fridge space seems the norm considering the door depth and handles need to be outside the space. Logically then the more bulky the door and handles are the more it will stick out.
Like others have said, I'm sure it will probably look a bit odd sticking out for the first few weeks (as our current fridge is small enough to fit well inside the space in both width and depth), but over time it will just become normal.
I really appreciate those who took the time to reply.
Normally the carcass of the fridge sits level with the cabinets and only the thickness of the door protrudes.
This will give you an idea. Perhaps see if you can get the tap moved slightly?
Thanks guys,
P_D
http://www.4cabling.com.au/desk-grommet ... -2184.html
http://www.jaycar.com.au/productView.asp?ID=HP1228
.....in a little alcove/niche in the wall behind the fridge space so it doesn't take up any space in the cavity". How nice is that?! Sensible builders?!
From reading this thread, yes nice, but possibly more sensible if it was (in a alcove / niche) in the cupboard next to the fridge ?
P_D
Haha PD do you like stirring?? Meh, I can live with having to move my fridge in the rare instance of a plumbing problem occuring.
Oh sorry, Not stirring at all EmyN
As I said, we're pigeon-pair people so it's not an issue for us, but I was thinking that with 200Kg of fridge and 50 kg of food and drinks inside, it's not something Mrs P_D would be able to move in a hurry if the water line let go when I wasn't home*.
Cheers,
P_D
*Things like this ONLY seem to happen to Mrs P_D, and ONLY when I'm not home
5
The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest.
29/10/2023
2
Hi, only for walking. It is a narrow 1.5m paved area next to house.
14/03/2024
Old Home Restoration / Renovation
Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts
