can anyone suggest a suitable product please.
I've built a floating tread staircase & have been using POR15 2 pak for the steel work & structural beams etc. I live in Cooktown & the heat & humidity have made application a nightmare - 4 times I've started from scratch to get a good / acceptable finish.
Anyhow stringer is done & looking ok but the steelwork for the balustrade support I ended up sanding back again & have used White Knight Squirts multi purpose enamel to do these bits of the structure. The finish is good but I want to use a product that will finish this so it looks similar to the high gloss of the black POR 15.
I would prefer to apply with brush or roller rather than spray & due to my bad experience of 2 pak would rather a single type product.
So looking for a clear high gloss top coat that can go over enamel
Thanks in advance for any help.
Cheers,
Chris
