Plantation ready built ??
Page 1 of 2
We are currently considering the following option
1. Buy land and build 2 stories house with Coral
2. Or Buy a ready build house by planation
Both the above are in the same location, I wasn't sure which is the most cost effective option. I realised that it I am building a house, it would roughly take 12 months and I have to pay 12 months rent and this being my first home, I was not confident about all the frills / selections process that Coral is going to take me through.
In case of plantation ready built, I just have to move in with every thing ready including the driveways, fences, drains etc. Also, I can move in as soon as possible.
I am not able to think of any things, could you please suggest what are the other points I must consider in this process.
I would negotiate the price of "ready build" house and make the most there.
chances are high that you buy land for (say) 500K. The moment you approach the build stage, the bank will revalue the land and the build costing.....chances are high that land valuation will come out lower.
Also the first home buyer grant..
Thank you that makes sense, I just saw the land of the ready build is valued at $280 while the new land I am looking at buying is in the same street is valued at $325K, which as you suggested on valuation would come down to ~280
Coral has given me a quote of $230 (base price) + 60 K for all the frills = $300K, which means, I am looking at overall spend of $325K (land) + $300k on building = $625K, which will take me 12 months to build. Adding another $20k for the rent I am paying now = total cost would be ~$645K
While, the plantation ready build is not ready for any negotiation as they have given us a 10k discount upfront (marketing gig), their price is ~$655K
I would like to know if option 1 would have any more surprises to my quote other that the initial quote given by the sale consultant? Are there any usual expenses that are not mentioned in the initial quote given by builders.
Thanks in advance
To explain a bit:
a) slope of land - this will require cut/fill, drop edge beams, retaining walls, additional brick work and many more
b) soil type - some soil types will require specific slab/foundation type
c) BAL rating - higher the rating higher the associated costs
The quote 230 K base did not include that but the additional quote of 60 k included provision for BAL rating and h1 soil.
But I don't see reference to electric, water supply, drainage assets etc. I will check with coral. If they are not including and if its gonna cost me around 10K addl, then I think you suggestion of going with ready built is better option.
Thank you so much, I am getting much clarity now.
Best regards,
Vijay
The pre-existing assets sometimes can become a headache (and extra costs) as your building plans will require changes to accommodate these assets (e.g) additional/deeper piering to protect the sewage lines, building restriction over/near those assets, tiger tails, relocation of assets, easement restrictions
I am not trying to scare you away from building your dream home....however it is good to know where extra costs can pop up.
Thank you once agin, this is exactly what I was looking for, the sales consultant confirmed that the charges are only from the building the house perspective and not from the land perspective.
Given this and the hassle of going through the process of building our first home, I am looking at buying the ready built which is on the same street and has all the frills that is in the coral quote and also the driveway, retainer walls, fences, landscaping.
Will keep you posted on how I go.
Are there any inspection required when buying already built new house other than building and pest? is there anything like a defect inspection etc?
I would recommend having a professional inspection done as that will identify any issues that require work under warranty. Even if Coral does not fix those issues at least you know what all you need to fix in the next 6-12 months. Coral may decline to fix certain issues if those are determined to be within allowable tolerance as per AU standards
just need your advise on what to ask the builder before signing a contract when its a already built house.
i am looking for the right word, may be a proforma quote or whats in house"" document, which has a list of inclusions in the house for example soil classification, type of slabs used, the make of the windows, the door, the tiles user, etcs..??
is there a name for such a document? Inclusions document?
Hi Sam,
In WA the document you are after is called the addenda.
The plans show all the sizes and details and the addenda outlines all the specifications.
Thank you Sam.
the builder just got back to me, i have pasted his response below, as I said earlier the house is ready to move, we are just unsure about the waffle slab, given the amount negative publicity offlate on various internet forums.
Any thoughts on this?
"There was no BAL rating on the block and the soil was H1.
So we did a H1 waffle slab and 90mm timber frame instead of the standard 70mm as we offer a 50 year structural guarantee"
Thank you so much.
50 year structural guarantee.
I am paying 650K for a double storied (ready built) and land is valued at 300K. I am not sure if its worth the risk. but the builder is plantation and are giving me
1
Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for…
27/05/2024
Hey everyone, With winter just around the corner, I'm starting to think about how to prepare my home and garden for the cooler weather. Winters can be a bit surprising,…
29/07/2023
We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some…
