We're building a new house and we have said that we will supply our own appliances with the builder to install them.
We have specified a "plumbed" steam oven in the kitchen.
Today I looked at the installation manual on the internet and it needs a plumbed water supply (not a problem, they can put a tap anywhere) BUT it ALSO needs a drain.
The picture in the manual shows the oven drain connecting to the fitting under the sink where you normally drain your dishwasher to.
Not a problem....
The problem is that our oven will be on a wall and the nearest sink is far away on the 'Island bench'.
So my question is, when the first-fix plumber does the first-fix DWV pipework is there such a thing as a 'sink' drainpipe that ISN'T connected to a sink that they can put in the wall to allow the oven drain connection to drain into ?
Hopefully the question is clear??
Thanks,
P_D
Drain In Kitchen For Wall Oven
4
Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for…
7/07/2023
2
Agreed. I just found out today the certifier has not given the final sign off.
20/09/2023
3
Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know.
