Hi All, Want to build a vertical timber screen at home (merbau 42 x 19’s) Plan was to screw the battens to the joists. However, interested to know if the joists should be screwed or nailed to the posts? Interested in thought & opinions. Thanks
Timber screen fixings
A screw fixing is always better, less chance of movement
Thanks Tim65, that was my expectation, I was concerned that rafter to post was meant to allow movement
1
Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity.
4/11/2023
1
You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of…
