Lapidary Wheel
I purchased a box of odds and sods from the Local Recycling Depot. There was an almost 6" Lapidary Wheel. I had no idea what type of wheel it as. I have a 6' Bench Grinder with two stones on rough the other fine. Not fine enough to sharpen knives etc. I fond out from the Web that it is for stones. My question is what else can you grind with it? Would it be suitable for sharpening Wood Turning Chisels?
How are you going with clamping up the timber for your hives ?
Stewie
Thank you for your reply. I am going to make a Sharpening Jig so that I can use the Lapidary Stone.
As for the clamping the hive parts together. I found that if after I placed the two clamps on there was was a bow, I placed a heavy weight in the centre so that it laid flat. I leave it until it is set and then put it through my planner. I have made 8 now. All squared, painted and ready to go.
Cheers Perry
Simple to make and you can usually make them from offcuts and left over timber. If you are interested I can whip up a quick diagram in my CAD program.
Stewie
I have seen ways of making clamps on You Tube. If you would not mind I would appreciate seeing your diagram. What is a Cad program?
Cheers Perry
Stewie
That looks great and easy to make. I go to the Recycling Depot. Every Tuesday. I can pick up timber and dress it to size. Thank you very much. I must have a go at this CAD
Cheers Perry
I looked on the Web there are so many DAD Programs. Which one do you suggest that I install that is free and just does the basic designs. Just the small projects. I really do not want to design an Englishman's Castle.
Cheers Perry
Stewie
I added something to your drawing. How can I add it to a message. I tried copy and paste.
Cheers Perry
Once it is on there, hover your mouse over the transparent bars on the top left of that photo and click on the Share button.
A new window will appear.
Click on the line alongside the IMG tag. That will copy it.
Just paste that into your thread here.
Stewie
The ones I made I'm pretty sure I screwed and glued them as they were all for a couple of benchtops 650mm wide and were for a one-off use for a mate.
Bolting them would make them more adjustable though and re-useable too.
In posting that photo you have too many img text tags in that line of code which is why it doesn't appear in your post.
This is what you have posted...
[img][IMG]http://i1104.photobucket.com/albums/h340/AussiePerry/Project1.png[/img][/img]
Remove the IMG ( and brackets around it ) text from the front and the second /img text ( and brackets around it ) at the end and your photo will appear.
Stewie
I am pleased you were able to see it anyway. I think I will make them with bolts so that I can adjust them.
I really appreceiate all you help.
Cheers Perry
