What would be the cost benefits of building a timber frame home with hebel veneer instead of brick? I would also like to hear if there are any hidden challenges with using hebel panels that outweigh the insulation and acoustic benefits of what appears to be an easy to install product?
Thank you to all for any advice.
Brendan.
Brick or hebel
Brendan.
8
This is 100% true. You can not hang anything on steel frames. very frustrating
6/07/2023
2
1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it
30/08/2023
4
Since you are in the design stage then I would direct your questions, in writing of course, to your designer. Depending on the trust you have in the competence of your…
