Comparing 3 phase oven to single phase
One has three phase power and the following electrical specs:
400-415V, 50Hz, 12.5kW, 3P+N+E, 17.4A/hr, 5 wire
And the other is single phase with the following specs:
230-240V, 1P+N+E, 50-60HZ, 4.7kW
Am I right in thinking the three phase oven uses a huge amount of power,
or does the three phase efficiency come into it ?
Thanks !
The oven with the high power requirement probably has a separate grill without the interlock so every element can be used at once.
If you have solar photovoltaics, and the sun is out, the lower power oven could draw a higher proportion of its power from the solar panels.
When i got no time to sit at the computer. I use tapatalk.
Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and…
30/12/2023
2
Hi Chippy, no there isn't, gave it a really good look through and literally opened everything and checked all edges as well. Hence the question, just hoping someone would…
