Cost to paint a ceiling..
In my humble opinion, the cost to paint a ceiling would be the same as to paint walls. According to the Archicentre cost guide this would be in the range of 11 - 24 dollars per square metre. I don't know if this helps.
No, I stand corrected. Just found this on the Home Improvements website:
All things considered the average cost of interior painting is about $16-$18 per square metre, including the ceiling, which is usually calculated at a higher rate per square metre.
I'd post the link but it keeps on coming up as forbidden text! Go to the Home Improvements website and look at interior painting.
Hi fruity,
Thanks Liliana
6
Thank you @ashington Homes for your reply! They just got back to me and offered credit for me to just take it as is. It was a less than quotes I got from ceiling…
17/06/2023
How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity?
28/06/2023
There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water…
