Is this a gully trap?
And then we have a long skinny one for in front of the garage, just looks like grates.
I would think the gaping hole is where the water goes in...? Or does the circle on top come out and act as a drain? In which case, I'm not sure about the gaping hole.
A gully is basically an inlet to allow surface run offs to go into which has a swan style neck not to dissimilar to the back of a wc so you will always have a level of water in it.
Those are not down pipes they Re the waste from a sink.
The idea is that if the sewer blocks the sewage will spill out of this rather than overflow into your shower tray.
Nope that looks like an overflow relief gully (ORG) It should be set below the floor level of your house.
Above post is correct.
The gully will be just either a square or round grid you will not see the swan neck as that is underground.
The two basins are on internal walls and the pipes disappear into the walls and the kitchen sink is on an island and the pipe goes down into the floor so I suppose the pipes were plumbed into the drainage system and this explains the absence of a gully trap.
Your down pipes will go into soak wells so a gully is not a necessity.
Liliana,
Don't go looking for soak wells - they are not applicable in Victoria.
12
Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather…
23/10/2023
10
If you have a floor waste, turn on your sink and put your ear down to the central floor waste and listen. If you can hear water running then they all connect there. If you…
