Garage Door
Colorbond Gliderol automatic Panel-Glide sectional door including Timberlook, Hampton, Tuscan or Oxford profiles?
Thanks
Both myself and my neighbor would not use Gliderol again because of their refusal to attend to warranty work.
What would you suggest instead (I'm in Perth)?
Can you tell what kind of door this is?
That's a Timber insert door from Centurion Garage doors. You would need your builder to quote it, but I believe most low to mid end Perth builders would charge a few thousand more than a normal garage door because it is real timber infill panels, don't quote me on that though but it's probably one of the more expensive options available from them.
If you don't want to spend quite that much but like the timber look, you could go for Centurion's Daintree range which most builders would charge about $500-$1000 more than a standard door, it is metal but is painted in 3 colours which gives it a real timber look, plus you don't have the staining upkeep of a real timber door.
I personally only have experience with Centurion or B&D Doors, they are two of the main garage door suppliers/installers for Perth builders, perhaps check out their sites and see if something takes your fancy
Are there any disadvantages in having this door over the standard panel door I mentioned above?
Love the look of these doors, however how practical are they? Do they get too hot in summer?
Dover white or surfmist garage door. I am having trouble choosing a garage door. The outside of house will be tranquel retreat. I want it to all blend nicely however I…
15/12/2023
Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture.
20/02/2024
My garage door has started playing up recently. Sometimes (and getting more frequent) when I press the button to open it, it wont. The motor is an ATA GD0-6V3. Red and…
