Removing stickers from merbau screen
http://www2.blackwoods.com.au/infoBANKP ... &P=2028411) was quite good - however as the sticker 'under side' wasn't exposed the patch was noticeable after removing it. I guess when you stain you can add more stain to that section?
I'd also be interested in any thoughts on this - I had the same issue, but as I was building a box, I just put the sticker side on the inside. I found using a paint scraper (something like the cheapest and easiest way to remove the sticky residue is with eucalyptus oil on a rag/cloth.
A tried and tested 'old fashioned' remedy that never fails, and shouldn't damage your merbau in any way.
good luck
Would quickly clean entire piece of timber after you have managed to remove residue especially If you are using a clear finish!
7
The best advice is for you to get a competent building consultant to guide you through your build
2/05/2024
4
thanks, yes they are dry , thats a good idea with fish oil as sanding will be hard
4/11/2023
1
You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of…
