Alfresco/Outdoor room - concrete by builder or not?
Our builder does not concrete the floor of the alfresco/outdoor room in standard (same for the porch). However we can do it as an option and would be part of the house slab then (cost is ~ $135/sqm).
What would be the pros and cons of doing this by the builder versus after handover?
If we want a timber deck is it better not to have concrete under?
Thanks in advance for your help
DKP.
I know some ppl think its a waste if you are decking, but I dont know when we can afford to deck, so at least in the meantime we have concrete there and not dirt/mud.
Even if you have to pay for the concrete
One thing we did find difficult, was making sure all the joists for the decking were level, as the slab was not in places, so the joists bounced around a bit. If there wasn't a slab there to start off with, it may have been easier to just dig the posts into the ground and level them that way...but you live and learn! Being a complete DIY job, there may have been an easier way to level them out instead of packing and dyna bolts...but we didn't know! We could have used leveling compound, but that's expensive too.
Also, having a concrete slab underneath, the water can sit ontop of it underneath the deck for longer than what would be absorbed by the ground. Also our deck is pretty much completely enclosed underneath because of the slab and water doesn't 'freely' drain away. It's only been down for a couple of months, and hasn't had much use now it's winter. The water used to pool near the back door as the slab wasn't level...but I can't tell you if it does now..must check next time it rains and I'm home!
The deck cost us just over $2K and 6 weekends...not sure how much a deck of the same size (7 x 4m) would cost without the concrete and on posts.
Long term, I cannot say what is better...I'll let you know in 5 years time how it's holding up! It was a pain to get it level and not 'bouncing' for complete DIYers!
It hasn't moved, and I don't notice the 'bounce'....but then it's freezing outside, and we haven't used it much yet! (Too much else to do!).
Anyway, it will be interesting to see how it weathers over the years with the slab directly underneath instead of soil.
Tiles straight over a slab would work either way, same with polished concrete.
But say you wanted exposed aggregate, post handover would be the only option.
2
thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and…
17/05/2024
My Electrical roughing is going on. What type of Outdoor heater recommended in Alfresco sized 3000mm x 3000mm below. I asked electrician to give 15amp power point in…
2/02/2024
Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill…
