Identifying an existing easement
landdata.com.au
hope this helps
Did you use a Settlement Agent? They would also have a copy of the Title (from the previous owner, and then a new one with your name on it once it has been transferred... they should send you a copy of your one, I think), and they'd have any other documents attached such as easements, covenants, etc. Contact them and see if they have any.
Your Agent will also have had to purchase a Title to have the property listed in the first place.
Do you have a copy of the Title from the previous owners, or a copy of the new Title with your name on it?
Failing all that, you can purchase a copy of your title from landgate.wa.gov.au.
2
You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work
15/08/2023
1
You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not…
24/01/2024
3
Thanks - yea sounds like I need to submit build over easement application....ugh guess I better start finding someone who can do the engineering drawings
