House being built behind us - concerned about height
Was wondering if you could give me some info. We've just received a notice from the council re our rear neighbours building a house and applying for a building permit.
Their house will be 8.15m from ground level...what is the normal height for a two storey house? I'm assuming this is above the average as otherwise we wouldn't have been notified...
We have views to our rear (sloping block so they are a bit below us) and are concerned that their house will block part of our views...
Thanks in advance!!!
Google says 5.5-6m not including roof (I have no idea if this is accurate)
As for regulations, I assume they are allowed to do this if noone objects? And they would be bound by the normal regulations in regards to window sizes and placements which overlook a neighbours property.
At that height, I assume they're raising their house? Our current house is very high - It's raised 1m off the ground
our plans, our home is just a fraction over 8m tall. Keep in mind, that's to the tallest point of our home. I believe council stipulates the maximum height allowed, and would assume it is different within each.
We're in the process of building a two story, and based upon Cheers Lou
2
House movement is always a potential problem and there is a cause. Yes you should have it inspected by a competent and experienced building consultant
14/03/2024
Old Home Restoration / Renovation
Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts
4/05/2024
1
I might be misunderstanding.... but I would be more inclined to cut a section out from the cinder block wall and place the cistern in the cinder block wall. Very messy job…
