Swimming Pool Coping Issue
Hope you can help,
We have just done a pool inspection on a property we have put under contract and the pool report came back with the below in regards to the coping around the pool. As the pool is only 2 years old is this of major concern. The inspector basically covered himself (as you would) and said it could become an issue but didnt specify how. The pool builder said it is not under warranty as it is not a structual issue more cosmetic. It is visable in more places than others but not unsightly. My concern is that the pool is only 2 years old and this has started already. Any experience or ideas would be appreciated.
Inspection report stated -
There are a number of sections of coping that are lifting from the pool shell.
The most obvious areas are around the small spa pool attached to the main
pool.
It is recommended that the pool builder who built the pool or a pool renovator be
consulted to quote on repairing the problem
Is it fibreglass?
Thanks, no its concrete with pebblestone.
No biggy, just take it off and replace it.
aside - Is there much of a gap between the coping tiles? ( existing)
Someone used a none-flexi adhesive.
Thanks again, just to explain without photos. The pavers seem fine, but about 1.5 inchs below the pavers in the pebblecrete there are long cracks but are small in width but cracks none the less. On one of the corners there are cracks that seem to head on angle toward the bottom which are more obvious and numerous. Does this help?
No skin off their noses
Or go to fair trading.
The builder said it wasnt structual and normal wear and tear and has a clause in the warranty to get around it.
However the vendor has done the right thing and got an independant inspector and he said what was posted by you which is the coping is failing due to the installation issues. They are going to fix it by pulling the pavers up, re coping and then tiling over the top. A good result all round as we terminated the contract this morning and the real estate was not happy. I called the vendor direct to apologise and we sorted it all out in 20min very amicably. I wish it could be this easy all the time.
Thanks for your help, much appreciated
2
The last home I lived in didn't have a pool and when i went to sell it the agents were not happy, even telling me to put one in to sell the place. The agents weren't happy…
13/07/2023
2
Thanks for that!
