Hi all, i wonder if anyone has had the experience of using fishing line to hold up insulation batts b4 the gyprock is installed? if so, what breaking strain f/line did u use and was it normal line or braided line... any info would be appreciated b4 i start.
thanxs tony
Fishing Line to hold Insulation batts?
thanxs tony
under the floor definately we were going to use hoop iron as we had heaps left but i like the sound of packaging tape ill be on the lookout for scaps next time we are near a factory area or shopping centre
thanxs tony
thanxs tony
Tony, I haven't done this, but I know a man who has. If you look on the website of Certainteed windows, www.certainteed.com.au, give the company owner Ross Wilson a ring. He is an energy efficiency advocate, and loves talking about insulation and other good stuff. He did just this in his own house.
JB
TimmyD - yes, the difficult area is in a raked ceiling which the gyprocker wants batts in b4 he starts, insulation retailer suggested f/line, i have d/brick walls, but have a vertical ceiling area. rest of ceiling is managable as it is flat.thanxs for other good link.
Ozberg- yes, would u believe the chap in fishing store had just done his & used "blue wovern plastic" packing tape...
Shelly the blue tape is certainly better than f/line cos its wider. i have c/raft floor so no worries there, u may also look at light weight wire netting for under floor - wouldn't be effected by weather?
JB i definately will use the tape. thanxs for other link, i'll repost once we have wrestled with this task for a day or so...
interestingly when i suggested to 2 insulation suppliers they give me 2 quotes on supply, other supply & install - they both ran a mile...not keen on raked ceilings!!!! when i mentioned main living area was raked, vertical then flat they both asked "who on earth designed that?" answer was Mrs V so nothing more was said, but i did get a very sympathetic look until i mentioned hard bit was that style around a 9m bay window - definately no quotes for installation then
all good fun, see if i think its so funny after 3 days up & down ladders....
thanxs again - cheers tony
For vertical installation you could use a staple gun (for anchor points in wood and thin guage wire (could even use plastic sheet with staple gun). For raked ceiling could you use wall paper glue sprayed onto one side of insulation batts? Just some mad ideas that may just work
Chris
So now i am building what i would call a rental. Never been so gutted with a company. Got the uneasy nod to DIY from one super to do it and then they change supers and they didn't tell each other that i had teed this up to happen.
My only advice to anyone is get it in writing that you are going to do it - i didn't thinking that a blokes word is good enough, it's not!!!
hope this helps others wrestling with raked ceilings..cheers tony
Well done Tony.
JB
cheers tony
4
yes it does, you've just not understood it. theres a difference.
