sky lights
I am building my home and thinking of installing a skylight (aprox. 900mm long). I will appreciate if anyone on this forum can share with me their experiences (pros and cons).
Should I consider having it done by the builder or should I consider doing it later?
Has anyone on this forum considering installing sky lights?
Hope you're in Sydney... top quality, double glazed... with instructions: -
http://cgi.ebay.com.au/Double-Glazed-op ... 240%3A1318
We had no problems with them, although you do have to get up and clean them every 6mths or so, moths and dust seems to collect on the screen a bit...
Go for it..
Annie
Judie
- check that the light tube will fit between ceiling trusses before cutting the ceiling hole
- check for electrical wiring in the ceiling before cutting the hole
- carefully hammer down the sealing strip (I also sealed with weatherproof sealant)
- give it a good check after the first heavy rain!
- wear a safety rope on the roof
- take all the tools you'll need in a big tool bag (getting up and down because you've forgotten wire cutters or something is a pain)
- clip that tool bag to something on the roof so it doesn't slide off
A reasonably handy person can easily manage them. I'm not a tradie, just a home handyman.
They make a huge difference to the light in the room, though they also funnel a fair bit of heat (they're on the north slope of the roof). If I had a choice, I would have mounted them on the south slope so they got all the light without the direct sun.
If you still want one you will need something that is energy rated. As large as 900mm it would liekey need to be double glazed - as it's on the roof, ideally with Low-E glass.
Ed
Both the ones we had installed were long rectangular ones, I think the small round ones are more for small rooms like bathrooms, toilets etc.
I guess they make the room warmer but cant say we noticed this.
We had them for many years, about once a year, take down from the inside (simple job by standing on a table and prising out by hand) dust and clean with window cleaner.
With skylights does double glazing and/or good design completely prevent the heat transfer ?. I am thinking about a skylight for my butlers pantry as it's windowless but I don't want to add heat to the room.
I would have thought it depends a lot on the type of skylight? If you have a super clear one with a large area then it probably makes a bit of difference. If you had dome collector passing through a hazy (pearl) outlet then I would think it would make very little difference.
Yes - double glazing and Low-E glass will make a big difference.
So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus…
18/05/2024
Which ceiling hook to use to hang Xmas lights under Eaves in 1st floor in 2 storey façade (no…
