What is the best material to use under paving stones on a dr
let me know if any anybody know about this
Usually, a combination of crushed rock or gravel and coarse sand works well.
For a base layer add in around 10 - 15 cm of either gravel or crushed rock and be sure to compact it properly.
For the bedding layer add course sand around 2-3 cm.
Take into account drainage, the soil type to begin with and also what type of vehicles will be using the driveway!
HTH
Mark
Which ceiling hook to use to hang Xmas lights under Eaves in 1st floor in 2 storey façade (no…
25/08/2023
2
Different to what others have said but thanks for that insight.
15/12/2023
8
Not recommended! The image presented is for a sublevel area. The footings are down deep with a load bearing wall supporting the upper floor level. If you did that drain…
