What’s the best part to extend these?
Storm water extension?
I’ve been digging up a path around my house. I’ve uncovered 4 of these, they had a mesh around them though. I need to bring them up to surface level with the path?
If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a chrome inspection opening that can unscrewed and removed for any required inspections. They look neat and can take traffic.
Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new…
7/04/2024
2
Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished…
23/05/2024
Hi all, I have a lovely two story mid century house built 1962 with flat roof, box gutters and wide eaves. Unfortunately a tree came down on one corner and damaged a 4m x…
