How should l remove rust from steel i beams
The rust converter is not critical but helpful if the surface prep is poor.
Surface tolerant epoxy mastics give best long term results. Jotomastic 90 is an example. better to get dulux or jotun industrial coating rather than DIY stuff. It will last a lot longer if the environment is corrosive, If you are inland, a couple of cans of fish oil is a good alternative
the better the prep, the better the longevity. I’d use a wire brush on an angle grinder with good PPE.
would a sander be ok or is wire brush better, probably a stupid question but could l damage the steel beams with the wire brush if brush off too much or in too deep? l am 4 km from the coast. if l use Dulax can you name the exact Dulax products to use. ALso what if l just brush off the rust and then paint the beams with fish oil, would that be enough, or would l also need to paint it with some sort of rust guard paint, perhaps galvanised paint
https://www.duluxprotectivecoatings.com ... al-web.pdf
https://www.duluxprotectivecoatings.com ... ration.pdf
read these two technical documents, you can damage the steel with a wire brush.
The first document tells you about the expected life in various corrosive environments, these products are expensive and some require special application equipment, go to a Dulux professional supplier and get some advice. You can also hire a mobile sandblaster.
https://www.duluxprotectivecoatings.com.au/media/2111/dpcsaubr001-as2312-brochure-final-web.pdf
if l cannot get a sandblaster would a sander with sandpaper be better then a wire brush. My plan is to sand the metal beams and then apply White knight rust converter to kill of the remaining rust and then paint it over with a Dulux rust guard primer and lastly a glavanized topcoat. Does that seem the right way to do it
4
thanks, yes they are dry , thats a good idea with fish oil as sanding will be hard
21/01/2024
22
THanks , l got a licensed building inspector to look at the rust, he said its just surface rust and it would take many years to become a problem because the beams are so…
7/03/2024
2
That just protects from further rust, l want first to apply a rust converter or rust killer to kill the rust thats there, whats the best one for galvanized steel
