Just a question in relation to the NCC 3.1.3.3 ,3.1.3.2
I don't have concrete done on the side of the house as of yet due to issues of water flow issues coming in from neighbour. The matter is before VCAT at the moment and had a joint Engineer do an
inspection on both properties.
The engineer has stated that my side does not comply with the NCC 3.1.3.3 ?
Does this only apply if you have the area concreted ?
I have more than 150mm from NGL to bottom of weep hole ,
I have a drainage point along the side on ground level (But has failed to report on neighbours pavement that is level with base of weep hole and has raised the NGL by approx 400 mm)
