Kitchen Renovation: DIY vs Resurfacing vs New Kaboodle
Am also not sure what to do with the countertop. 90% of it is in fine condition...it's only around the sink area where it isn't as good. The tap has previously leaked so there's a large crack/gap between the countertop and wall tiles. A small section of the countertop to the right of the sink is also a little hollow due to the leaks in previous years. Is it a good idea to resurface/overlay the countertop as am not sure how easy it would be to replace it with a new one over the existing cupboards?
Am hesitant to do a full renovation as we live in a small apartment and don't want to disturb neighbours for weeks or be without a kitchen for weeks but if the cost of ordering a full new modern Kaboodle/Ikea kitchen and hiring someone to install isn't that much more than resurfacing, then would that be a better option?
- replace your counter tops entirely,
- replace all drawer runners with soft close runners,
- for cupboard and drawer doors: remove, repair, replace door hinges with soft close hinges, repaint and re install with new handles,
- repaint tiling if you want a change.
I purchased all my most recent kitchen reno gear from Bunnings (Kaboodle). I totally demolished my old kitchen, purchased all new cabinets and counter tops and did all the work myself. This was my second kitchen reno.
None of this involves a lot of noise. If you are concerned about noise then simply chat to your neighbours and coordinate a time that suits you and them. If you are handy, or willing to learn on the job, then DIY will save you many thousands (even tens of thousands) of dollars, now and into the future. If you are careful and take your time then you are likely to do a better job than any tradie you could hire.
Remember that electrical and plumbing (water/gas) work is best left to qualified trades, especially since it appears this may be your first exposure to such things. There can be legal ramifications if you tamper with some types of electrical/plumbing gear.
1
a building inspector should be able to tell you about any major problems but we need a floor plan with dimensions to clarify options for extra bedrooms ... sometime an…
11/03/2024
2
I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major…
6/02/2024
2
No access to subfloor unfortunatly. I drilled a small hole and missed a stump , I plan is to cut a man hole and do a proper inspection
