Mounting heavy 75 inch TV
I need to install almost 40kg heavy TV unit in the commercial building. I was thinking to use flip toggle bolt (https://www.bunnings.com.au/tox-m5-flip ... t_p2260712) but after drilling a hole I found out there is about 30-35m gap between concrete wall and gyprock. The toggle bolt requires minimum clearance 50mm.
Options:
1. The TV mount is about 900mm wide and would overlap only two steel studs.
I was wondering if installing MDF panel over the gyprock and secure it with just metal screws (into studs) would be sufficient?
Once MDF installed, TV mount would be screwed on top of MDF.
2. The second option would be to cut gyprock out and install MDF right on the concrete wall. Then put gyprock back, patch the wall and install TV mount with timber screws.
3. Is there any other solution/screws that would help me to avoid using MDF or cutting gyprock?
I would be happy for all suggestions.
Peter
Hi,
Options:
Peter
Options:
Peter
Peter
I would go with Option 1 but swap MDF for 12mm ply. Save you cutting holes in your gyprock
We use 12mm ply all the time with out TV installs but normally mount that before gyprock.
Good luck
Cheers
Simeon
Thank you for your advice.
I installed TV mount with only two screws that went into studs and use two additional 20mm "GripIt" plugs. These plugs requires only
small clearance behind plasterboard walls.
Regards
Peter
Hi Simeon
Regards
Peter
Regards
Peter
Good job Peter!
Great to see that you found a solution
Cheers
Simeon
I wonder how would you install MDF or ply? On top of gyprock and into the studs?
Yes. Exactly that.
Alex, yes you just screw through the gyprock into the studs
1
What size are the windows, double or single glazed, can I have a pic of the full windows inside & out? If you can see packers please take a pic.
