We own the front lot of a subdivided parcel of land and have a condition on our land providing right of carriageway / driveway for the battle-axe property behind us. We are looking to build a new house on the front lot and the council has just advised us that we cannot count the 'access handle' / driveway in our Floor Space Ratio calculations.
Can the Right of Carriageway be excluded from the FSR calculations? The driveway is counted towards our land size in the Title Search.
FSR - Right of Carriageway
Welcome to building in Ryde!
I am 99% certain you can use the right of carriage way for the FSR calculation. I am speaking with my designer later today so I will double check and if the advice is any different, I will let you know.
Good luck with your build
Simeon
If you have a 'common property' like this (https://ibb.co/Smwgqqf) both 37 and 37A can use 50% of the 'side driveway' in their open space calculations.
If the driveway is all for the rear house like this (https://ibb.co/yPtn2HV) then the back house (31A) can use all of the driveway as it is all their land. The front house can use none of it.
A lot of the battle axes around us use the first method to give the front house extra building allowance.
Again that's my limited understanding from when we looked into buying the front house of a battleaxe.
I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different…
27/02/2024
3
They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper?
7/04/2024
2
Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished…
