Builder using 10mm plasterboard instead of 13mm
Our house renovation drawings specify 13mm plasterboard for all internal walls, however, I noticed our builder has used 10mm instead without telling us. It very much seems like a cost-saving for the builder as 13mm is double the price of 10mm. I know there are 10mm plasterboards suitable for walls but isn't this going against the contract to substitute products without notifying the client?
Thanks in advance!
Maybe they thought the drawing were old standard specs, can’t see any real benefit in using 13mm, could be an innocent mistake.
Who did the drawings for you?
The only place we use 13mm (I work for a builder) is external ceilings
If its been specified it should be 13mm, its very unusual to have 13mm on internal walls though.
Hi Doozer
I hope you are living the dream, building custom homes in beautiful COVID free WA.
Over here, we mainly use 10mm in new builds with lightweight frames unless the clients have a particular acoustic requirement, but often we use 13mm in the older renovation homes/apartments or in any direct stick situation.
In the area that we are in,( North Shore Sydney) we often come across double brick homes & apartments with structural cracks in the double brick walls.
After stitching the bricks back together we like to recommend gyprock as opposed to render on the internal walls as we think the finish is much better, and the 13mm direct sticks to the walls better.
For new builds where a client has a particular acoustic requirement ( such as a home theatre or master bedroom), we recommend using a double layer of 10mm gyprock combined with acoustic insulation and acoustic sealant. Those seem to be a good combination and are pretty cost effective.
Anyway, have a great day
Cheers
Simeon
There is no excuse, builder signed off on 13 mm plaster and that is what you should get. Unless you have specific requirements 10 mm for walls should be OK but the builder should give you a credit for difference in cost saving on labour and materials.
Unless the builder knows you are onto him and unless builder pays he will do it again.
Hello,
Thanks in advance!
Thanks in advance!
Hi bc89
You might want to consider whether or not the works breaches section 18B of the Home Building Act.
It may or may not be a defect, depending on the particulars of your contract. You may want to reach out to a specialist construction lawyer in your area and let them examine your contract and other documents related to the build, so that they can advise you on possible next steps.
Cheers
John
4
What we have done in a few theatres ( including my own) is run 2 layers of 13mm gyprock, but sounds insulation especially for the bass is really tricky as a lot of that…
6/05/2024
Plasterboard (13mm) vs VJ Panels – for interior…
