Setting up a home theater in a new double story build. The ceiling on ground floor is completed, as is the flooring on the first floor. In between the cavity space, we need to install a HDMI cable which will run through the beam/joists from one end of the room, to the other (about 8 metres). With the both entries sealed, no manhole or anything, how do gain access the cavity space without breaking into the new ceiling or floor above?
Any help or info would be great, thanks.
How to access double story cavity space between floors?
You'll be cutting holes in plaster now.
2
get some pool noodles and then bark mulch over the top
28/12/2023
We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions…
14/03/2024
6
Old Home Restoration / Renovation
To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,…
