Cracked roof tiles
Save the hassle and just buy replacements and change them yourself.
If you don't have any roof tiles left over from when they built the house then go and buy what you need to replace the cracked tiles plus another 10 - 15. Just with expansion and contraction as well as some hairline cracks that may get worse as time goes by let alone having any tradies up there servicing anything on the roof, you will get more cracking.
I used to tell clients of mine to do the same with any ceramic tiles when we did bathroom renos.
Stewie
We will get Boral to inspect the rest of the roof, but I guess my concerns are: will the inspector be honest if he finds many cracked tiles? And if there are cracked tiles there too, I would assume there is a fault in the batch of tiles - who would be liable for replacing them, and would the tiles under the solar panels also need replacing? We are also in contact with the builder who suggested we contact Boral in the first instance.
Stewie
Thanks Stewie, we’ll see what Boral and the home builder say.
Did you get a response?
Is so common and just way to much room for errors.
Stewie
1
how on earth did that happen? the tiles need to be replaced, I’d be checking the concrete slab too, either tile needs to be loose or the slab cracked I would think
23/07/2023
3
Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know.
23/12/2023
Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the…
