What would you expect?
Page 2 of 3
I didn't even think to pull out the tin left over. It says "full gloss enamel" Does that mean it's oil based? It doesn't say on the tin. Although, looking at my trims and doors compared to what Bubbles has experienced, they don't seem that bad, so thinking it's not oil based. The tin just says white, and on top they have written trim whites, but there are a few letters with numbers next to them, so would that be the tint?
I was thinking about this last night, and it's all good to say there are so many whites, it's your fault, but really, shouldn't builders take on more of a role in making sure the client understands that? I knew there were a hundred different whites, hence why I asked for a pure white like the ceiling white and I still didn't get it. What about those building for the first time and have no idea where to even start. Surely builders need to start taking responsibility on making sure their clients understand exactly what they are getting! Not just paint, but lots of areas. We had a pretty good pre-start person and our builders were fantastic with helping, but I know they aren't all like that.
(rant over)
You're right though- I agree that it should be THEIR responsibility to make things more clear at the selection meetings and request that information be recorded in a way that makes it clear for both the builder and the client. After all- there are codes for door types and sinks- it is not unreasonable that they should record more specific info about paint colour. (Unfortunately it seems that it doesn't always work like that!)
I would have expected it to be white (like ceiling white) too! We are doing our own painting and our paint colour is White Duck (We are having half strength) and I can tell you now that "White Duck" isn't actually white- although the name implies it. It is stone/grey type colour and to use that as an example- I would be mortified if I indicated "white" on paperwork and a colour like White Duck was used on our ceilings. At the very least they should have clarified with you.
Just as a spin off- Your post reminded me of the paint colour in my current house. We didn't built it but moved in when it was about 18 months old. We needed something small fixed up while it was still under the builder's warranty and the work required a small area of painting. According to the paperwork- the paint is supposed to be 'whisper white'. The painter walked in and immediately stated- "This isn't whisper white". He managed to tint the paint and sorted out a colour match but the colour of the house isn't what's written on the paperwork. I'm not sure whether the people who built the house were able to change their minds at the last minute and the paperwork wasn't adjusted OR whether it was painted the wrong colour (despite the paperwork having a colour and code recorded in it)
Just looking through the paperwork and the ceiling says "white" and the trims, doors etc say "white" funny how they are two totally different whites!
Our last house we built, we had a feature wall in Donkey. We kept saying it looked way more purple than on the sample, but were assured it was donkey and samples aren't always accurate. Funny when we had a crack fixed up and the painter went to pain it, that the donkey he had was way less purple! He had to scrape a bit off and take it to get the colour matched.
So your house may have been the mixers take on whisper white lol.
We choose a solver colour called paper white. I just said i wanted a glossy coat on the doors, not semi-gloss but full-gloss. I have no idea why the dumb a+++ painter would then get oil based paint.
Do you think the paper white colour is mixed with the oil base? Can they do that? And also it doesn't explain why the cavity slider has gone yellow.
Hmmm, an email off to the builder is in order. I hope they fix this for me but I am not holding my breath
My husband then reveals to me that he is using oil based paint. He hasn't bought it yet as he isn't up to the skirtings and architraves yet. I freaked out because I certainly don't want ours yellowing over time but my husband says it is more durable. He is by no means an experienced painter- Is he right? Is it considered more durable? Is there a way we can use the oil based paint and avoid the yellowing? Does the yellowing have to do with brand/ quality/ application technique? Does anyone have an advice they can offer or some evidence I can use to convince my husband that using an oil based paint could be a mistake.
Is it considered more durable? - Many would say so, I disagree. After all, you're not going to drive a herd of cattle alongside your skirtings, would you. Some common sense applies regardless of paint type. Oil paint is not a no-fail, last-forever-as-on-day-1 either.
Is there a way we can use the oil based paint and avoid the yellowing? - Unknown to me, so I'll say NO.
Does the yellowing have to do with brand/ quality/ application technique? - NO.
Does anyone have an advice they can or some evidence I can use to convince my husband that using an oil based paint could be a mistake. - Yep. Buy ANY water based paint brand, eg. Taubmans or Dulux. Please be careful as these days they make non-white paint bases too
.. convince my husband that using an oil based paint could be a mistake. - You WILL be nagging him for the rest of your lives if he goes ahead with this annoying thing of the past - oil paint.
All paints which you buy in the shops would state if it's water or oil based (even if it's in the fine print).
So, this is inconclusive - so far.
http://www.dulux.com.au/specifier/produ ... ducts/trim
tells you which ones to use for non-yellowing
Miss, I was just looking at the dulux site, show him this tells you which ones to use for non-yellowing
Is it a plain tin, non-branded, no stickers? If not, maybe you could post a pic??
No, it's dulux. The side with the small print on it is all painted on, which is why I can't find whether it's oil based or not, but looking at the dulux site it is.
So it's oil for sure?? 100% sure??
Builders and painters should be made to sign some pretty ugly doco that if they accidentally use oil paints that they have to fix it plus pay you LDs for the stress and pay you a weekend or two in a resort to try to shake it all off!
No, seriously, I honestly think that acrylic paints are a dream to use inside of the house for the usual things such as the trims! We even painted our external doors in water based pure white - nothing happened to it despite all that afternoon sun!
But, you can always fix it. It's not even that hard (except for the knees if the skirtings are attached).
I have actually noticed the same thing as Bubbles, that the cavity slider is actually a lot more discoloured than the rest... wonder why that would be?
I find it strange they even try to sell this stuff. On the dulux website, it clearly states that if you do not want yellowing, then use the aquamarine stuff!! If they know it does that, then why sell it in the whites?
We were told it happens due to lack of natural light. The doors spend more time closed than open so they are in the dark, the effect is more noticeable. This is the same at my place and also on the inside of the broom cupboard and linen cupboard doors.
I don't see any problems with oil, apart from it being more smelly and taking longer to dry. It's far more durable (I used semi-gloss acrylic on a built-in wall unit and a set of bifold doors in our old house and it was a BIG mistake; lots of scratches from normal usage
But, check your contract and specs - if they specified water based, they would have to fix it.
You can tell by looking at the cleanup instructions. If it says to clean up with turpentine, then it's an oil based paint.
Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second…
12/11/2023
13
Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini…
18/01/2024
Hi It came to my attention after the handover that - The facade cladding on the face and the side are not straight. -The face tapers down by 50mm from left to right and…
