Browse Forums General Discussion 1 Oct 15, 2016 4:40 pm Just a quick query regarding a rear fence height. The regulations of my estate state that the rear fence can be a maximum height of 1.95m My neighbours either side of me have a retaining wall at the rear of their properties and have put the fence on top of that which then makes the fence substantially higher than 1.95m (over 2.1 metres tall). The owners of the two houses directly to the rear of me have sent me a quote for the rear fence at only 1.95m high (no retaining wall) which means the fence heights to the rear of my property will be lower than the rear fence of my neighbours on either side. My question is, when the regulations state that a rear fence can be only 1.95m high does that mean that is taken from ground level, or are you allowed to build it to 1.95m high on the top of a retaining wall. Thanks. Hi all, Our boundary perimeter fences need replacing (3 sides). From everyone's experience, what would you install? Timber lapped and capped OR colorbond? Thank you. 0 3135 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8695 |
