Browse Forums Building A New House Re: North Shore Newhaven (Sydney) 62Dec 27, 2016 10:06 pm Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 63Dec 27, 2016 10:11 pm Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 66Jan 04, 2017 8:45 am Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 68Jan 04, 2017 11:19 pm Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 70Jan 05, 2017 9:45 am Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 71Jan 10, 2017 10:35 pm Build thread - viewtopic.php?f=31&t=83484 Our Glendale 39, SA Re: North Shore Newhaven (Sydney) 72Jan 10, 2017 11:14 pm Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 74Jan 19, 2017 5:08 pm Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 75Jan 19, 2017 5:52 pm Nev _________________ Blog | ( will start once received tender ) H1 thread | https://forum.homeone.com.au/viewtopic.php?f=31&t=77665 Re: North Shore Newhaven (Sydney) 76Jan 19, 2017 8:10 pm Neville S Any movement on your site this week? SM is on holidays, I have only seen movement on one site near me but not much. My External walls on ground flr were meant to be done this week and scaffolding put up. Haven't checked this week, but will let you know. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 77Feb 09, 2017 8:43 pm So quite a bit of progress since I last wrote. 1) Wall wrap was replaced with the correct one, thank goodness. 2) Ground floor hebel was put on in two days! Some minor things.... i saw in one place the dynabolts for the top hat rails weren't in properly in one place and so they may not hold the 90kg panels properly as designed. Otherwise looks like a good job. Again anticorrosive paint was not applied to exposed reo which is disappointing. 3) Front portico piers and frames have been constructed. 4) Plumbing rough in done. 5) Further bracing completed in the house and frame bolted down to slab. 6) Scaffolding erected this week 7) Had site inspection to discuss quality issues. SM rejected my request so I escalated to CM and quoted the relevant contract paragraph entitling me to access. Meeting held 2 days later. Things discussed were internal stair treads not same length, wall wrap ripped in places, roof sarking hanging out in one place, fixing of chipped slab, hebel not properly brought right down in one or two areas meaning slab will be exposed, roof joists are bowed. CM has agreed I can have a hand wash basin in my upstairs WC. I met with plumber on site to discuss which was nice. Was also great to see him working on Tuesday when it was pouring down with rain but he still kept going because the roof was on which is excellent. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 78Feb 10, 2017 11:18 am Good to hear about the progress. Sounds like you are on the ball with everything. I had areas of the wall wrap ripped also due to strong winds however I didn't raise it as an issue. A couple of areas were not covered and when I raised that with my SS he just said that it's not required since the area already had ply over it. I know I could of taken it further but chose to leave it. I think it's great that you are pushing them to fix them all and you'll end up with a great house. Hopefully it doesn't wear you down to much, Re: North Shore Newhaven (Sydney) 79Feb 10, 2017 11:59 am Drove past today, first floor wall wrap being installed with top hats and then hebel to go on next week. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 80Feb 15, 2017 1:24 pm Good progress! Did they agree to fix the rips in the wall wrap? Hi i am looking to buy an investment near by North Rothbury. How is this area? is there schools inside this estate? please advice good builders around that area to buy… 0 3021 The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18195 Hi, can anyone recommend a custom home builder who can build in north east area? Looking to build a custom 4-br energy-efficient home with a max budget of 750k. If they… 0 22812 |
