Browse Forums Building Standards; Getting It Right! Re: Data/Phone line 10Jan 15, 2016 12:53 am cat_dunc Crazyk I'd be concerned about that pooling water against the foundation Yeah it's sure not ideal. You should have seen it before we put in drainage. We've got another drain to do then it will all be sorted. I hope you're not on reactive soil then Re: Data/Phone line 11Jan 17, 2016 2:26 pm Slab Heave Recipient cat_dunc Crazyk I'd be concerned about that pooling water against the foundation Yeah it's sure not ideal. You should have seen it before we put in drainage. We've got another drain to do then it will all be sorted. I hope you're not on reactive soil then Geotechnical report says "Class P (Problem Site)". "Noting the 'P' classification we recommend that the footing system be proportioned to minimum Class 'M' requirements.." Thoughts please? Re: Data/Phone line 12Jan 17, 2016 3:37 pm Regardless of soil classification water should not pool against foundations. Put it this way.. Say in 3 yrs your slab developed a crack and you left the landscaping as is. The builder would be free of any warranties because you neglected to follow proper landscaping drainage as per AS & CSIRO recommendations. During the build the builder has a responsibility as mentioned above to maintain site drainage. Re: Data/Phone line 13Jan 17, 2016 3:56 pm Yeah they didn't maintain drainage during the build which was a bit distressing to watch. We're in now and have had keys for 3 weeks. It's our top priority and will be fixed hopefully within a month. There's 64 l/m of wall to build, it's going to take some time Fingers crossed (very tightly) no damage caused within that time period. Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20651 If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13846 4 10822 |
