Browse Forums Landscape & Garden Design Re: Landscape Inspiration & Design Concepts 397Feb 19, 2017 9:00 pm We are just going through costs this week. We've finally come up with a landscape design we like. I'll be sure to let you know orph! My thinking is, it's going to be enough to run a small country for a few years - otherwise known as Kym - Re: Landscape Inspiration & Design Concepts 398Feb 19, 2017 9:06 pm needsausername Oops. Pressed enter too early. At this stage we are looking at http://www.quickstone.com.au Each block weighs between 500-700kg so once in place it won't be going anywhere. And it also means we wouldn't need a concrete footing as it uses crushed and compacted road base type stuff. We do have close to two pallets of bricks left over so we are considering using them to do the front retaining and then having a go at rendering ourselves Do you know what the delivery fee is from nowra where their located Re: Landscape Inspiration & Design Concepts 399Feb 19, 2017 9:14 pm Not too sure sorry Sandra. We are building on the fringes of Jervis Bay so it's fairly close to us. Where abouts are you? - otherwise known as Kym - Re: Landscape Inspiration & Design Concepts 400Feb 19, 2017 9:15 pm needsausername Oops. Pressed enter too early. At this stage we are looking at http://www.quickstone.com.au Each block weighs between 500-700kg so once in place it won't be going anywhere. And it also means we wouldn't need a concrete footing as it uses crushed and compacted road base type stuff. We do have close to two pallets of bricks left over so we are considering using them to do the front retaining and then having a go at rendering ourselves Are you laying these via a hi-ab Crane? Landscape Design Parramatta We have been doing a large amount of landscape design work in Sydney… 0 3 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24830 Thanks very much! And would the landscaper/contractor generally involve the engineer or is that something the client would do? Thanks for your help 2 10005 |
